NJ 3D Printing
FutureSigns
I have to quote a job that calls for a eagle on flag and was thinking instead of carving the whole sign out of HDU on our CNC we'd 3D print the eagle and apply it to the sign. Does anyone do this sort of work. I do not have a vector layout yet. Please see attached.
  • Sign Option 3 (1).pdf
MGB_LE
Why not carve the whole thing? I'd be afraid of long term performace of the 3d printed eagle outdoors.
tulsagraphics
3d prints aren't suited for long term outdoor use. ASA filament would likely be the "best" choice for UV resistance and durability (a nightmare to print with by the way, and toxic), but even with ASA + UV clear coat you'd be lucky to get a year or two out of it.
WildWestDesigns
Poly carb I think would be the best. Nylon may work, but I could see UV breakdown over time. ASA I would put below poly. TPU may be 3rd after poly and asa. PETG would be like 6th. I'm more resin kinda of guy, but I wouldn't use that outside, it certainly would yellow at best over time and wouldn't give over weather fluctuations over time either). But I use it more for figures/toys etc.
tulsagraphics
Ah! I didn't know they had polycarb filament. I'll have to look into that.
Yeah, I could see resin yellowing pretty fast. I suppose if one were so inclined to use 3D printing as part of the workflow, or at least conceptually (for a durable piece)... They could use a 3D model to create a plaster mold along with fiberglass / epoxy to build up some thickness, then sand / prime / paint. Of course there's still the issue of printing a 5ft or 6ft wide model on (presumably) a printer that has a 10" x 10" build plate. Good luck getting those parts printed without warping, let alone the assembly (ugly seams).
I don't know if thermoforming over a 3D model would work (depending on the required oven temp, like in one of the pulled plastic face ovens), but it should work fine with an open frame vacuum former.
In any case, I think the OP would be hard pressed to find a faster / more cost-effective solution than a CNC outsource.
FutureSigns
Been a while, Here is the completed sign. A local artist hand carved the eagle. Sadly it was his last project. He passed away in August. :(
  • I Appreciate You
Reactions: 3 users
Kev-O-Rama
FWIW, there's a company north of you in North Bergen that apparently does 2.5D and 3D routing out of various materials.
https://www.rshapes.com/
We've done similar shapes (7' tall police badge in 2.5D out of HDU) in layers of vector lines using roundover router bits in the CNC with great success. Might be something to look into.
Worse-case scenario, Wayfair sells 2.5D spread eagles out of aluminum, but their heads look down, not up.
Good luck!
;) https://www.wayfair.com/outdoor/pdp/24-aluminum-wall-eagle-decor-vfhd1066.html?piid=9245135
