45.1:03
Today in the middle of printing I got the error. 45.1:03 Wondering if anybody has some info on this error. I have the service manual which only has an error code 45.1:00. So I believe it's tied to this:
SE Code: 45.01:00 - Rewinder Servo Shutdown
Problem Description:
Problem with the Rewinder servo
Corrective Action:
• Check the spindle is correctly inserted into the Printer.
• Load the substrate again making sure that the media is straight and that a ‘bubble’ is not formed on
the media path. Do not rewind manual the media when the printer is checking the roll.
• Check that the Spindle is not damaged and the gear at the end the spindle is correctly attached.
• Perform 3.1 Rewinder Motor service test ⇒page 133.
• Check the Rewinder motor cable is not damaged and is correctly connected.
• Replace the Right Roll Housing assembly ⇒ Page 579.
• Replace the Rewinder Motor ⇒ Page 361.
I've checked these things and this is the second error I have gotten in two weeks. Wondering if anybody knows what the :03 is for.
