4x6 sign, pricing
OldPaint
if you built it right........no problem
you seen the mailbox 4x4 set you buy? with the 2 notched?
do same thing only give 24-30" above the intersecting 4x4's, (to a 3-4" eye bolt) attach a guy wire with adjuster....from top of vertical 4x4 to end of horizontile(2 1/2 eye boltat the far end ) 4x4....and tighten till level...
it called load bearing thru triangulation....doing what i suggest is gona put all the weigt on the VERTICAL 4X4...where is should be.
Kysparky
Was planning on running a brace on the 2 post similar to what you said O P.
That's a lot like a diaganal on a gate. Same principal anyway. I want to thank everyone for the imput on this. It's just a simple sign but it's what the customer wants. Some of the post have given me other things to offer and do so no matter how small the project these forums can be great. Once again, thanks all.
OldPaint
4x4 upright.....the way i said will support a lot more weight then that 4x8. 6x6 is over kill....to do same as 4x4.
increasing the distance between up above the tangent, will help trasfer wieght.
simpler way to figure is angel of attack on the guy wire.
45 degrees is best, no less then 30 degrees for optimum weight transfer.
learned most a this stuff as a draftsman))))))
mikefine
You didn't ask for feedback on the design, but who is Eddie Sights? What is important is that he does Auto Body work. Unless he was a ball player or rock star or has a tremendous ego -- Auto Body should be primary and largest on the sign...Michael
Kysparky
Everyone in this little city knows Eddie Sights does body work. It's just where he is located is a little out of the way so he needs something saying "Here I Am" Showed him Pictures of the sign by itself but when I showed him the pic I have here it said SOLD! He knew just what it was gonna look like. If it wasn't fer puters I'd be dumber than a box of rocks. lol
