5 Layer Printing Help!
rhill
Printing on a Clear Cling.
5 Layers.
Layer one is Color
Layer two Is White, 100% magenta Changed to Mono white Resulting to a White Plate
Layer Three is Black, Tried 100% black and Also 70% black Changed into a shading plate
Layer four is White (Same as other white layer
Layer five is color.
Ive changed the resolution to 1200
THE PROBLEM
When i go to Composite all the layers the preview is grayed out and when i print it of course it looks just like the preview. What am i missing?
signheremd
If your colors are spec'd as the newest Pantone shades (Pantone 2 I think), the printer is not licensed by Pantone to print those and thus turns them gray. Our Mimaki does this
Goatshaver
Shaving goats and eating bushes
Should be working the way you have it. That's very odd it prints out that way.
Do you use hot folders?
Goatshaver
No I do not use hot folder
Or a favorite....if you don't I'd set one up to make sure that all the files have the same setting to begin with then change the layers (white) to what they need to be. It's very strange that it would let you output it looking that way, that seems to tell me something with the layers aren't correct.
I've never had that problem and I've only tried this a couple times. I'm sure you've followed their guide on 5 layer printing as well.
