6 ml vinyl for product labels
Bryce I
I'm Brie
We print a lot of sheet labels and stickers on oracal 3164. 4 ml . A client is asking if we can produce their labels on something thicker. Any recommendations for a 6 ml 54" or 60" wide, white print media? Something comparable to 3164?
All insights welcome!
WizardWorks
General Formulations just released a 6mil with air egress backer gf222AE at print united. I got a roll from Polymershapes last week and it is AWESOME. Easy peel, easy apply just like the 201HTPAE albeit slightly lower tack, so it can be moved around during application but goes permanent after 24 hours in situ.
hybriddesign
owner Hybrid Design
we like 220, sometimes if it's on a really curved surface it's too thick though and won't stick. For instance wrapping around a 1" diameter pipe or something.
WizardWorks
in cases where the 6mil is too thick, the 201htpae (a 3mil) is ideal. I have a label customer using it around corners on frozen food items and it's performed wonderfully.
Richardwt
You could try a 6 mil cast or polymeric printable vinyl, depending on whether the client needs extra durability or just a thicker feel. Make sure the material is compatible with your printer, ink, and application surface, and test adhesion before running the full job.
jfiscus
Rap Master
You might want to request to see a sample of what they are looking for. We have a lot of customers that we do the majority of their labels on standard vinyl/lam combos, but a few of the labels we have to print onto Arlon DPF8000 (which is thicker) due to the installation substrates. We also do a lot of reverse print decals on Gerber LexEdge (polycarbonate) with 467 adhesive on the back; these are a lot thicker than standard vinyl/lam.
MarkSnelling
Drytac has a few good options:
Ctac 6mil Perm or removable with air egress 54"x150' $340.11. This is a monomeric 6mil and is a great price for what it is. If you want long term outdoor performance, then I'd use the polymeric version which has 54"x150' rolls selling for $400 and this is good for 5 years outdoors.
I should have stock in Vegas
