7.6 help again please
AirJordan
My new problem. When I go to cut plot and the window comes up all my sizing is much larger then what was desiged. Example:say I want to cut 10''x12'' product manager will have it cut 14''x20'' This is not actual numbers just an example that it wants to cut every thing to big. :banghead:
MikePatterson
Head bathroom cleaner.
It will also default to the cutter size. You can set up other sizes in the production manager and just select the size vinyl you are using.
Example would be if you have a 54 inch cutter and load 24 inch material. It will default to the 54 inch size but you can change it.
MikePatterson
I am an idiot i guess. I guess my part timers kicked in and I miss read the problem, thus gave an answer that did not apply.
Yes sounds like the % is off in production manager.
Note to self read twice answer once.
