A-boards
ChiknNutz
Just curious what some common/average prices you all are getting for A-boards. Reason I ask is I did a couple a while back and believe I under-charged. Now I've quoted a couple more and now they seem too high (to me anyway). This would be based on a dbl-sided 32" wide x 48" tall A-board (or thereabouts). Say one or two colors of average copy/graphics - no digital printing.
WVB
are you making these out of MDO or are you using the prefab ones you just apply vinyl to?
Webbum
I just quoted one yesterday, one color vinyl for 219.00, and the customer thinks it's to high.
ChiknNutz
I use the prefab ones I get from a local supplier. They make nice ones from MDO and cover them with vinyl. The cost on these in a 32 x 48 white is $65.52, colors are $77.26 and dry erase boards are $133.77. I did a single color one (with a 2-color arrow) for $190 - dbl-sided. I just quoted one the other day that was yellow background and black text/graphic for $342. The first one seems too low but this last one seems too high. Thoughts?
WVB
We use the Signicade Portable Display Sign (Rugged plastic collapsible A-frame with handle which can be filled with sand/water) close to your measurements would be 45"x25" with yellow background & black text/graphic would be around $300
quicksignguy
Chris, I just priced a 24" x 32" - 1 color vinyl on white A-frame at $195.00 Cdn. You're probably real close. I'd stick with your prices if your customer is OK with it.
D
