A lot of light pink mist
Jharris81
I feel like a have the answer but just wanted to run it by real quick. I’m getting a lot of magenta mist around all my prints and even on my media hold down on my xc-540. The test prints all look relatively good. I just replaced my light magenta head about a month ago. I have never replaced my magenta head since I bought the printer 3 or so years ago and it was used. Here are a few test prints when I was adjusting the head to try and turn it in a bit. I’m guessing it is the magenta head that need replaced.
It's probably the head unfortunately. These heads can fire multiple sized dots. The nozzle check only fires the largest one but most color profiles use variable dot. So that's why your nozzle check can look perfect but still have issues. You could try new head cables and clearing out the terminals where they plug into with air duster. Sometimes that will do the trick with this kind of issue. I can't remember on these older Roalnds but on ones newer than it, if you run the nozzle check in service mode, it will print the smaller dots and you can confirm my theory if the small dot section looks messed up.
Jharris81
I did run the fill pattern awhile back for another issue and the edges were very misted. As I said I figured that was the issue but just wanted a second look. It’s super old head from the looks of it anyways. Appreciate the replies
