A slight stutter a little hesitant on FC9000 when moving along the carriage.
Mata
Hi all
I'm not sure if I am going crazy but watching the FC9000 cut some stickers I notice a slight stutter the head is moving along the carriage. It is cutting ok but vertically perfectly and when doing a die cut it is perfect, when cutting along horizontally especially on a die cut, the cuts aren't as nice.
I've tried cleaning the carriage bars and got some dirt off but that has made no difference which make me wonder and I imagining this and it's part of the cutter or has dirt got in behind the head and needs removing and cleaning?
If I move the head with my finger, I can feel a little resistance every inch / couple of inches as described when cutting but as I say, I'm not sure if this bus the norm?
Can anyone confirm if they have this?
Attila Nagy
It is a common fault with Graphtec cutters.
You can find a plate spring at the top of the carriage. It holds the 2 rollers. 3 screws hold the plate. Release the 2 screws at the sides, the spring will tighten the carriage. Gently secure back the screws. While tightening the screws back, make sure not pushing the carriage down.
When taking the top cover off, be careful not to damage the ribbon cable for the control unit.
You might need to move a little board away at the top of the carriage. It has cables connected, easy can be damaged.
PM me for contact details if need assistance.
Mata
Thank you, I'll take a look and contact you if I need any help. Thank you
Mata
So I took the carriage off and checked for debris etc, bearings all seemed ok, put it all back together and now I am getting a cross cutter issue e01019.
I didn't make not of how high the the motor part on the carriage went if that makes a difference. I can cut ok, just not cross cut without the error. Any ideas?
Attila Nagy
If you have not follow the steps I have written, you have done nothing. Probably just let some dust to the encoder.
Release and tighten back 2 screws, and the plate spring does the job.
Mata
All ok now, I didn't set the height of the head correctly when I put it back on. I needed to be 10mm above and I was lower which was giving me the error.
All working now, thanks.
