Graphic Realm
I know it is vague not detailing the amount of work and what not but it’s simply just a speed issue
For the things you are router cutting, are the complex contours or more square cuts?5’x10’
ACM, Coro, foam, ultra 6mm pvc
Was it one of the edge machines or the C Series?I went with Esko over Zund
If they already have a colex, that can be used for more heavier duty processing.I’d look at cutworx, they have a great line up that would likely fit the bill.. centrally located as well.
https://www.cutworxusa.com/
