Rant Adobe CC Starting To Require Windows 11
Graphic Extremes
Knows To Little
Well it has started, Adobe CC has started requiring Windows 11 or it will not download some of the updates to programs. I use Adobe Bridge because it makes it easy to look at all file types and actually see the image or artwork rather than just seeing it is an Illustrator program file.
The latest update requires Windows 11 so I contacted Adobe. They replied that they are making all updates to programs to require Windows 11 in order to get updates. They are no longer going to support Window 10.
I have extended support for Windows 10 for a few more years, I guess it will be time to start figuring out how to remove all the spyware from Windows 11 and debloat Windows 11 to make it a usable product.
WildWestDesigns
It happens in the Linux world as well, unless one compiles the software from source, but even at that, may have to compile from an older release as Qt or GTK version that they are using requires newer GCC etc. So it's probably as simple as the compiler that they are using has symbols that the old run time isn't able to handle. Which has been a thing for decades.
The thing with Win 11 is that due to the perpetual internet connections that one needs to have (if not for Windows itself, but for certain functionality in Adobe), have to always be checking after each update if have to strip away something that the update put back in (or may have removed that you might actually use). That is always going to be a game of catch up. Having said that, not a fan of using 3rd party solutions to handle debloating. Some are perfectly fine, I'm sure, just the mere fact of having to do something like that 3rd party, just already setting things up for a bad situation. Why I will always argue that the 9x era was the best era. It may not have been the most computationally powerful era, but it certainly was the more user powerful era. Even as more systems were coupled together, it was still possible to strip those things out without totally neutering other functionality, not the case today, but I digress (as I always do).
  • Agree
Reactions: 1 user
