and rubber blast mask or floor guard. My best tip is to get as many "grips" as possible. Your long run print jobs will thank you.Take your most thickest material and most complex job, go test that on the cutter. That's about it. If you do colored or reflective test that.
or cut .5" text on brushed aluminum vinylTake your most thickest material and most complex job, go test that on the cutter. That's about it. If you do colored or reflective test that.
