AGFA Anapurna h1650i led black ink leak.
Petor
Hi, my anapurna leak black ink and i can see de vacuum pressure go un and down most frequently than normal but only the black head leak ink. how is possible? if there is a vacuum leak, shouldn't all the heads leak? or there is a one way valve that block the leak?
Can someone help me?
The printer starts not printing black anymore, then starts printing black again, then stops printing black.
When i stop it I can see the drops on the head go back in the head. why if it lost vacuum?
Thank you
LilRonnie
Hey not sure if you fixed this but I had a similar problem with my agfa anapurna M2050, it ended up being the float sensor not being fully sealed and leaking air, needed a new float sensor and ptfe around the threads.
