AnaGraph Express 75-E random restart
Briansos
Greetings,
The company I work for uses an ancient plotter I've never heard of: AnaGraph Express 75-E. Anyway, the past few weeks its been plotting away and then it will shut down, and restart for no apparent reason. As you can imagine this is disastrous for long plotting jobs. Has anyone who uses one of these (ha ha) have/had any issues like this? I have no clue as to what is causing it.
Thanks for your time.
Techman
A very good cuter in its day,, It had a problem with the power supply and motherboard.
So with this machine the power supply is failing. It will be dead soon and then take out the motherboard. Or, it is in the process of killing itself.. This is a common problem with that cuter. One day it will just crash and never work again. That day is fast approaching.
geb
Ancient, I'd take that cutter any day, providing it was working good. Haven't had that problem with any I use, it is only happening on long plots? Perhaps http://www.apdevices.com/support.html the answer is here.
George
edit: I see Techman has provided a solution, I really like the anagraph cutters I have and appreciate the info.
