Analysis Of Test Print Sp-300i
bquinn
hi all,
I tried searching test print pattern analysis etc but couldn't find an answer. Probably due to how I was phrasing it. Anyway, my black pattern looks funky. I did powerful clean as well as clean heads etc (yeah I did touch heads themselves with solution and swab but thankfully I don't think I made it worse. Attached is a photo. Thought advice or direction is greatly appreciated.
CanuckSigns
it doesn't look horrible. does it show up under normal printing conditions, i.e. can you tell these is an issue on your prints?
You can try soaking the head in cleaning fluid, if that doesn't work and it's affecting your output you may need a new head.
bquinn
Thank you for the very fast response! I assumed it was the problem when I printed some American flags for a local fire dept. (Photo attached)
And although I'm a bomb tech fir my day job, I'm afraid of taking off the head as I've never done it before
CanuckSigns
that print looks worse than I expected given you are only missing 8-9 nozzles. Try running in high quality mode, it may help lessen the issue.
If you are not comfortable replacing the head, i would suggest contacting a roland dealer in your area to do it for you, but expect to pay about $2-3k for it.
Alternatively, there are a few merchant members on this site who can sell you the head and offer you step by step help over the phone to walk you through it, if you are used to disarming bombs, i'm sure you can handle changing a print head!
bquinn
You would think :)
I'll try the high quality mode but I really appreciate the quick reply and assistance CanuckSigns.
bquinn
Thanks again, canuckSigns, print quality is much better on hi res but now for some reason, the carriage will go across paper and back then pause for a few minutes, then do another pass, then wait some more. print never gets completed and i've restarted both computer and printer. I don't mean to keep going back to the well, but i don't know what could be causing this.
CanuckSigns
is your printer connected directly to your RIP computer, or does it go through your network?
If it's direct connect, i would look at the cable itself, or your port settings
if it's through the network, hook it up directly.
bquinn
You're the best. thank you so much. Hooking it up directly worked so must have been some network issue. Thank you again!
Bruce
