Anothe Graphtec Robo Question
juan45215
Just bought a CE5000. Connected it to Vinyl Master Pro (com1 port) and cut with no problem. Then I connected to Cutting Master from a differnt PC (USB port), also cut fine, but when I went to back to the PC running VMP it cuts the file 400% larger than what was sent.
Could running Cutting Master change the setting on the cutter? Is there a setting on the CE5000 to magnify the file?
