Anyone know why one color won't show on test print no matter what? Mimaki JV300-160 Plus
hamedsalehi1
First a little of the yellow color was gone when I test printed, then I soft cleaned and the whole yellow was gone, so I filled the ink of everything then, all of a sudden almost everything was gone! So I refilled again, and did around 5 cleans, hard and soft and medium. Everything was back perfectly but the yellow would not come back, I changed the dampers, a tiny bit of the yellow came back but then was gone again. I even swapped some tubes/lanes to see if the lane is clogged but it was all good, I did everything but the yellow would not come back whatsoever. I would really appreciate it if someone has any idea what could be the problem, anything helps, I'm really out of ideas.
Inkjetparts
if ink is getting to the damper fine and you already swapped lanes then its down to the head or the cap. look at the cap top on the yellow row, if the rubber is worn or crusted it wont seal and the pump cant pull ink thru that channel no matter how many cleanings you do. swab it with flush and see if it seals up, a lot of times a new cap top brings the nozzles right back. when you do a cleaning does ink actually get pulled into the yellow side of the cap?
hamedsalehi1
Yes when I do cleaning ink clearly moves into the head very clear through the lines and through the damper into the head. All clear
Smoke_Jaguar
Leaning towards new head. Cap issues tend to manifest themselves more along the edges than smack dab in the midst of the head. Time to pull out the checkbook!
Could swap the line pair between head 1 and 2 and try that. But sounds like you know what the issue is and want to try everything before replacing the expensive part. I get that.
If you get ink through the lines, check the dampers, if the dampers are doing a good job of supplying the head, check the cap, if the cap is good, try the waste pump, if the pump is cleaning well, then replace the head.
hamedsalehi1
"Hi, thanks for the answer! I swapped the lines and replaced the damper with a new one. While changing it, I saw ink coming out, and the new damper filled up with ink. Sometimes when I fill the ink, a few small spots show up in yellow, but after running a cleaning, they're gone."
cornholio
How do you fill the ink? What ist the ink level in the damper after the cleaning? If it's empty, maybe there is a small leak somewhere.
dtfonestop
The detail that a few yellow dots show up right after you fill and then vanish after a cleaning is a good clue. It usually means the head can still fire that row, but it isn't staying fed, so I'd chase air or suction before buying a head. This is the order I'd go through:
1. Watch the yellow damper right after a cleaning, like cornholio said. If it goes flat or the ink level drops and stays low, the head is pulling air from somewhere instead of ink. Check the joint where the damper meets the head inlet (seal or o-ring seated, nothing cross-threaded), the fitting on the top of the damper, and any tube joints you disturbed when you swapped lanes. A leak there can be too small to drip and still starve one row.
2. Make sure the new damper is properly primed and full. If it was filled from the top only, there can be an air pocket sitting right at the head inlet. Priming it by gently pulling ink through from the head side gets rid of that.
3. Do a manual suction on the yellow row. With the head parked on the cap, gently draw on that row's cap/waste line with a syringe. If yellow comes through in a steady stream and the nozzle check improves, the pump or cap seal isn't pulling hard enough on that channel during normal cleanings.
4. Soak that row. Park the head on a cap that's wet with flush or cleaning solution and let it sit overnight, then do a normal cleaning and a nozzle check. Dried ink right at the nozzle plate can let a few nozzles spit after a fill and then quit.
5. Read the line swap carefully. If the blank row stays on the same physical spot of the head no matter which ink feeds it, the problem is in the head. If it moves with the yellow ink, it's on the supply side.
If the supply side checks out, the damper stays full, suction pulls ink cleanly and a soak doesn't bring it back, then that row of the head is most likely done, and at that point the checkbook comment is fair. At least you'll know you didn't replace it for something a seal or a soak would have fixed.
Smoke_Jaguar
You can also check for cross-flow and delamination by gently flushing each head channel with the dampers off. If you push flush into one channel and it comes out the feed port of another, the head is definitely bad.
hamedsalehi1
I have checked the ink flow and damper side—ink comes through cleanly when filling/drawing ink into the damper, and the damper stays full of ink. However, there is still zero Yellow on the nozzle test print (even though the actual printed output in my photo looks surprisingly acceptable).
At this point, I suspect the electrical side may not be sending the firing/drive signal to push/fire the Yellow ink .I verified that Yellow ink comes through when filling, and I also filled it once with cleaner and then refilled it with Yellow ink through the ink supply line/pipe. The damper fills properly and holds ink
Has anyone run into this exact symptom where ink fills fine and print output doesn't look obviously ruined, yet the test print shows nothing for a color and turns out to be a flat cable, blown fuse, or head/board signal issue? What specific checks or measurements should I do next? pls chekc picture maybe Kdo something's wrong
hamedsalehi1
How is my actual print output still looking decent when Yellow is gone on the test print, and what mistakes/actions could make the head dead same this ? Tell me what not to do so I don't kill the head. and in first only show small part of cannel is not work but after clean totally gone
dtfonestop
A few reasons the print can still look okay with yellow gone: yellow is the lightest color, so it hides well, and on a lot of photos or artwork the missing yellow just shifts things a little cooler or duller rather than looking broken. Look at a skin tone, a bright yellow logo or a green, those will show it right away.
If ink is reaching the damper fine, here's the order I'd check the electrical side, always with the printer fully powered off and unplugged before touching anything:
1. Reseat the head cable (the flat ribbon) at both ends, the head and the carriage board. Look at the contacts and the ribbon under good light for any brown or burnt spot, a crease, or a contact that looks lifted. A cable that's been folded or pulled a bit can drop just one row.
2. If yellow shares a head with colors that print fine, the signal is getting to that head, which points back to the yellow row itself (clog or damaged nozzles) rather than the cable or board.
3. If you can borrow a known-good cable or swap two cables of the same type (and only if the manual or a tech confirms they're identical), see if the missing color follows the cable or stays with the head. That tells you which part to buy before you spend money on a head.
4. If you still think the row is clogged rather than dead, park the head on a clean, wet capping station with the correct flushing liquid for your ink and let it soak overnight, then try a normal cleaning and a nozzle check. Gentle is the key word.
What NOT to do, since these are the common ways heads get killed:
- Never plug or unplug a head cable with the power on, even for a second. That's the number one way heads and boards die.
- Don't keep running strong cleanings on a row that isn't firing. Hours of cleaning cycles with nothing coming out can dry-fire and overheat those nozzles.
- Don't push flush through the head with a lot of syringe pressure, and don't use a cleaner that isn't made for your ink type.
- Don't rub the nozzle plate with paper towels or tissue. Use a lint-free swab with the right cleaner, and only dab at the edges.
- Don't leave the head sitting uncapped or with a dry cap overnight.
- Make sure the cables are dry and fully seated before you power back on, any ink on the contacts can short the head.
Your note that only a small part of the channel was missing at first and then all of it after cleaning does suggest the row itself was starting to fail, so the overnight soak and the cable swap test are worth doing before you decide to buy a head.
