Anyone still using a DC4sx / DC5sx?
Iconify
Long shot I know - but I have one and It still works flawlessly, very niche market printer but it's served me well.
I'm really just needing some help tweaking some settings for the metallics (which I hadn't used in ages). Metallics get treated like spot colors which means they should just-print, but Im not getting the quality from my metallic silver as I remember and I also can't remember if I used to change settings to run them, or if it was very sensitive to the type of vinyl I was printing on...
Anyway I'm just trying to jog this memory of mine and determine if I need to let the metallics go or however it works out.
Iconify
Here's a couple pics of how the metallic silver was laying down. Also a bit of a thin look on the spot black. I have had this machine since maybe 2011 and have not had a single service issue with it, but also - never made any adjustments along the way. I started all the calibrations and whatnot and that all checked out. Next I figured I could try metallic gold and see if it was going to be the same as the silver. It was.
Then I dug into the manual and the menu and played a bit with the density settings. I had been running my machine at 12400 since day 1, never messed with it. All the materials I've run thru it never gave me any trouble. But my vinyl is probably old, I know my ribbons are old. I guess the machine needed a bit of a boost. I eventually landed at a density of 13200 and everything started looking like I have always remembered... Will switch back to silver and give that a go again.
cornholio
Could be your ribbon is overaged, or the medium isnt suitable. Otherwise you could try to raise the overall "Density", to adjust the medium, or by ribbon, if it's just the metallic.
