Aptos font is bad!
Bobby H
Arial Sucks.
Does the macro automatically release clumps of grouped letters before applying the weld command? Welding over the overlaps won't work if the letters are grouped.
myront
Dammit, make it faster!!
It works on grouped text. Tested using X7.
Ronny Axelsson
Have you tried welding text without converting to curves first, Bobby?
Convert to Curves creates a group of several objects with around 600 - 700 nodes each, while Weld creates one single object (there is most likely a node limit though).
If you then have to perform a second weld to make sure all overlaps are removed, you can do it directly on the already welded object, while you have to ungroup the group first.
I don't really need a macro for this (sorry Myron ;)), since it is so easy to hit Alt+W (my Weld shortcut) twice.
  • First Place
Reactions: 1 user
myront
I like that discovery (weld twice).
The macro is useful if you have many different colored text or groups of text. Retains colors & retains separate text shapes. Plus I don't have to look down at my keyboard to find the shortcut :)
  • Agree
Reactions: 1 users
Stacey K
I like making signs
Just had this one the other day.... Bahnshrift. Good times. You mangle one (large) cut job with something like this, and never again forget to look at it in outline view before calling it good to go. Fortunately I caught this one... it was a different project that learned me good.
I used that one for a logo and ugh...every time I use it it's a pain!
  • Agree
Reactions: 1 user
Bobby H
Arial Sucks.
Yes I have. Applying my keyboard shortcut for the weld command on a live text object (set in a variable font) results in the same bad outcome. Many of the overlaps in the letters turn into negative holes. I'll often test this using Helvetica Now since its variable version has a LOT of overlaps. I get the same results in CorelDRAW 2022 and the new 2026 version. It's easier just to click Ctrl+Q (convert to curves) and then Ctrl+U (ungroup) before applying my "W" short cut on the clumps of combined letters.
Ronny Axelsson
Haven't got Helvetica Now here, but have you tried applying a second weld to it?
Every variable fonts I have tried has been perfect (as good as one could expect) after a second Weld.
myront
If anyone is interested in trying it. Just change the extension to .gms
  • SmartWeld.zip
Bobby H
Arial Sucks.
Applying a second weld to the lettering can be hit or miss at correcting the overlaps in converted/grouped letters or letters that are still live text. I think some of it depends on how long the text string may be.
myront
I've since perfected the macro to account for this.
