Arizona 360xt doesn't start
AlsEU
Check, if the LED diodes on the computer motherboard and mainboard are on when you switch the printer on. If not, check the power supplies.
SignMeUpGraphics
Super Active Member
Power supply should be standard ATX. If you have an old working desktop around, swap out the power supply for the motherboard and see if it fires up.
Does the rest of the machine start up when you power it on? eg. Ink pumps, vacuum pump etc.?
AlsEU
The ATX power supply is powered from the AC breakout board located in the electric box (near the main switch). There is a separate fuse for this line, it's F4 (4 amps). Maybe it's only the fuse (but question would be, why it's broken...). Of course, it may be also related with the breakout board itself.
And be very careful during work with electricity, it's dangerous.
Deymos1981
I had it. You need to download the manual for the motherboard. See where the button on/off should be installed. Close the two neatly dins. Voila.
