shoresigns
You're only partly correct, if a PDF is secured but with printing enabled. If printing is disabled in a secure PDF, then your workaround does not work, since most PDF apps respect the security settings.You cannot 'lock' the document. You can always print to PDF which makes it a regular PDF
