Bad rolls of 3m IJ180Cv3-10
klingsdesigns
Has anyone else received these rolls. About every 18 inches into the roll there is about a 4 inch run across the roll that doesn't print right?
strypguy
Yep. I found this on some of the original IJ180 as well. Not sure what the deal is but I just keep sending it back until I get a good roll. It's become a pain in the butt since I've had it happen on about every other roll I order. John
klingsdesigns
I got two in a row, so now they sent me one from a different state so hopefully I have better luck now.
strypguy
I've ordered from two different vendors with the same problems so it's probably a widespread problem. John
jfiscus
Rap Master
We go through about a roll each or both 48" and 54" 180c here daily and about a roll per week of the 180cv3, but we only use it in 36" widths for a certain customer.
Never had that kind of trouble that I can recall.
jaylem
what about heat
never had a problem with Arlon 6000XRP. Less expensive than 180cv3 as well.
after reading your advise I checked out the cost on fellers and they indicate not to use heat during application. what's your experience?
MikePro
I've been dealing with their laminate separating from the adhesive and shrinking 1+ inches on all sides. Their supposed cast 8508 seems to be anything but.
that's their calendared overlaminate.
8519/20 is 3M's cast overlam
