Barcode Reader for Multicam using enRoute
ProdPrintMan
We were able to get our Onyx Thrive to print the registration cut dots for our Multicam thanks to this forum (THANK YOU!). Onyx then creates the xml cut file to a folder I created that the enRoute computer can access on our server. We were thinking of adding a barcode reader to the enRoute computer.
- Any recommendations on this process?
- will enRoute accept a barcode reader?
- will it work with xml files?
- bluetooth or usb or 2.4 dongle?
found this, wonder if it would work: Amazon link - Eyoyo barcode reader
Any recommendations or suggestions would be great! thank you!
PrintTech$
Coreo Command can read 2D barcodes. I am assuming the Enroute can as well. We bought the USB barcode reader directly from multicam, they provide instructions on how to enable the barcode reader (and what barcode type it needs) as well as how to set the default file opening location . It is slightly expensive for what it is thru MC but it works. The operator needs to have the software open, choose the left Open tab, and you can open any file in the folder specified. I cannot speak to the XML files working but it seems like it could work. we output DXFs from the RIP as we are mostly drag knife cutting so the pathing is not needed as tool associations are setup.
