Goatshaver
Yesterday I was cutting sheets in OPOS Sheet mode and one sheet came out with the two last pieces not even cut, didn't attempt to cut them, next sheet it didn't attempt to cut 7 of the last pieces on the sheet. All the cuts were in the cut file.
Today I came in and this is the same job I'm continuing on and decided I'll just use the barcodes, Load it up start the server and set it to go it tried to read and says "Sending File Failed...." then disconnects.
I deleted all the cut files in the folder and resent the one I'm trying to cut. Started the barcode server and the same thing tried to read and then just disconnects.
I tried cutting one with just using OPOS, NO barcode server. Sent the file from Onyx Cut Server, it immediately started looking for the marks, found them and started cutting....then after it reached the end it started looking for a barcode when it's not even set for that, it's set to OPOS XY.
Something weird is going on and I'm not sure what it is, or whats causing it.
