Its called UHB, ultra high bond.I didn't know Oracal made VHB, thought this was a 3M only thing, will look into this!
what kind of substrates are you using this with?3M VHB can be used in many sign applications including outdoors.....IF, the application is done correctly. Available in gray, black and clear. In various widths and thickness. Go Thicker is for imperfect or textured surfaces.
Applying 3M™ VHB™ Tape
3M™ Adhesion Promoter 111
acrylic FCO letters attached to red brick outdoors is the most extreme case we've had. No holes were allowed to be drilled in the brick wall. 10 years ago and still holding!what kind of substrates are you using this with?
