Question Best Panel Saw for the Price
Erin Smith
We currently have Safety Speed Dust Free Substrate Cutter, but finding we are needing panel saw for cutting 6mm Max Metal. What is best system for the cost and best supplier? Pros/Cons to adding this piece of equipment welcomed too.
signheremd
Safety Speed Panel Saw (H4, H5, or H6). An H5 will cut 5' tall panels vertically or can be turned to rip them, and is a good choice. Cons, makes dust. Pros included an option to hook up a vacuum to minimize dust and the ability to cut nice square panels. Different blades may be worthwhile if you cut a mix of materials (acrylic needs a special blade, but ACM and MDO wood can use the same blade). Try not to drop material on the plastic rollers - the are replaceable but you will need to adjust them so they line up properly with the others (to keep your material level).
Reactions: 2 users
2B
Keencut 98" SteelTrak Cutter is what we use and we regularly cut 6mm ACM and 080 Alum
ikarasu
You cut .080 aluminum on a steeltrak? Seems like it'd be a little (a lot) too thick for me. It says it can cut .040 which still seems a bit too thick for a non blade...
How are the edges?
Reactions: 1 users
2B
We have a staffer who is 6'7" and #400'ish, so a "normal" person would have issues cutting the thicker materials
the 6mm is more often than the 080 alum
The edges are good, no burs or jaggedness
have been using the cutter for 5+ years in this manner
d fleming
I have a 26 year old sawtrax panel saw. Just put a new blade on it. Works perfect. But then I'm the one who uses it, not an employee, lol. It used to be the blade size was hard to find if you could at all outside of manufacturer and they stuck it to us hard. Just picked up a grest blade for about 40 bucks fr cutting acm. Not 250 like the manufacturer still advertises.
