Best wall mural media
MarkSnelling
Mark Snelling - Hasco Graphics
Hi Mark,
I would be interested in talking to you more about this as well as getting some samples of each version that we can show out client. Doing some large mural wall mural pints for indoor use, current projects t will do in a restaurant. Looking for something that will print reliably with mimaki UV ink roll fed. Want to able to install it with the least amount challenges. Will be installed over painted drywall. Would like to get clean seams that do not separate, be able to make corrections while installing if we are slightly off on alignment. Don't want to get call backs for seams opening up over time. Client wants to be able to wipe it down if needed due to a customer splashing something like a drink, or kid wipes hands on it, etc. Anyway, please let me know what is the best way to talk to you in greater detail and see if these could be a good fit for us. Thank you so much!
Retac checks all of those boxes. The adhesive has the ability to be applied and removed a few times without losing the ability to stay put. The film has no stretch and it is 6mils thick making it very easy to apply. It will print UV just fine. If you need a test roll, just email me your FedEx or UPS number and if you want the Smooth, Canvas, Linen, or Sand texture. The only place I've seen failures is when people tried to install it on freshly painted walls. If the wall was painted in the last two weeks, then I'd apply some Wall Size primer (you can get on Amazon or at an Ace Hardware) which dries in under 2 hours and then apply the Retac to the wall. If it was painted a long time ago, you will be fine. My email is [email protected]. You can call as well 216-903-8313
