ced64k
Hi,
Here is my first post, I'm newbie to sign printing
 I have two questions :
- I want to make 2 graphic kits for dirtbike. But these motorcycle are little bit old and not very common so base template in pdf or something are not available. What's the best to make a template ? Masking tape ? Other adhesive films ? The surface is not flat, it's a lot of curve, little holes, etc. Then I intend to scan these template, redraw everything in Illustrator and make sure that will fit perfectly with the correct scale.
- For printing I have a friend who works in a coworking specialized in printing. Printing on vinyl shouldn't be a problem for them. But I don't have a clue about what kind of materials and printing techniques needed for dirtbike. It must be waterproof, highly adhesive, resits to gasoline, rocks, etc.
I read that it's generally solvent or latex printed on vinyl with a laminated layer of thick transparent vinyl and then precisely cut with a vinyl cutter machine. Can you recommend me some vinyls and printers generally used for this ? The goal is to ask to correct thing to the printing guy
Thank you
Thank you
