lrsbranding
What am I missing? We have a Tajima TMFX II-C1506 and a Barudan BEVT Z1501. The Barudan will sew all day long and never birdnest. The Tajima will drive me crazy with random nesting. It will randomly birdnest on the bottom side on any one of the heads with any color and with any type of fabric. It will do this several times then run great for a while. The stress of waiting for it to eat a Nike drives me crazy. I don't know what to check. It happens regardless of the bobbin tension. I use a Towa gauge and have tried anywhere from 1500 to 2500 mN. It will do it with either prewound paper bobbins or magnetic. I have replaced all the bobbin cases, I have sprayed the hooks with cleaner. Don't see any damage. Have set the hook timing with the RhAT Tool. The I and FOX tests look good and the machines sewing quality is good. Can the felt disc's on the upper wear as to still sew good but not enough friction to stop the pull through? Is this just a normal problem for this machine? We can't turn our back for a second. Makes it hard for one person to hoop and sew.
