Bleed of multicolor object
msenjur
hello
how do you make bleeding when there are multicolors in object? it there some function that would do this?
i got these files where bleed was ok, but i doubt that author did it manually...
i got this logo and i dont know to create such bleed....
thanks for replys!
In these cases I usually select all of the objects I want a bleed around, copy and then paste in front, meld them together and expand, then just use the path offset function to set the bleed where I want it.
myront
Dammit, make it faster!!
bleed had to be done manually. Method depends on what program you use. Pretty much the same process just different terminology.
"stroke" = Adobe
"outline" = CorelDRAW
"gradient fill" = Adobe
"fountain fill" = CorelDRAW
"clipping mask" = Adobe
"powerclip" = CorelDRAW
msenjur
ok, that is also how i do it...
but what about in corners? see corners in first attached picture...
