justin_92_92
Hey guys,
I just sold my Sp300 to a buddy to add to his shop. We printed some stuff at my shop and then loaded the printer up and off to his house. Ive moved it a few times in the past as well. He told me he was getting really bad prints. I went over and saw he was getting something we always called "block printing" where the black and cyan would almost smear from one side to the other. I checked the continuity on the two fuses (f2,f3) and found f3 to be blown. I replaced the fuse and tested it and blew the fuse again. to make it easier ill post below what ive tested.
unplugged the two cables at the main board and turned on - fuse stayed good (eliminate the idea of bad main board that way I read)
Swapped the ribbons at the print heads and blew the other fuse as well (f2 was likely already blown and swapping it blew f3)
Anything else I should be doing to test? could be a bad print head Im guessing but would like to rule everything else out first before I drop the money on the head. That head has a new ribbon cable from head to board so I dont think its that but possible. I checked continuity and the ribbon seems good.
Thanks for any help. This has me stumped.
Justin Robinson
Justin Robinson
