BN-20 Not finding crop marks
MakeMyGraphic
ok dokey, so I am trying to print and cut with this new BN-20 a friend of mine is letting me use (he is letting me try it out before I make the jump), but he never once tried to do the print REMOVE and then contour cut feature on the machine, I loaded media, printed with crop marks then removed, laminated, replaced (have the recommended lead and rear excess material for the contour cut feature supposedly) when I try to run CUT ONLY feature in Versaworks the machine looks for the first crop marks but then BN-20 utility has a pop-up saying "crop marks not found" and cancels the job... there are clearly crop marks on the material so I am not sure what is going on there :\ anyone have any suggestions?
dcurtisroland
Really glossy laminate can have problems reading. The other option is to not laminate over the crop marks. Make sure the software utility and firmware are the latest versions. If you're still having trouble give our tech team a call and they can log it in the system so we can notify engineering.
800-542-2307
-Dana
Rob_maxgrafix
just to cover all bases, are the first two crop marks in line with the cutting strip? if not, then it wont be able to find the marks.
