"Burn" looking marks on material
rydods
Member for quite some time.
There's a sign we put up last year and it looks as though the material or laminate is darkening in a couple of spots (photos attached). Any idea what might be causing this or how we can avoid it. It seems to be only at the top of the sign. Material used, Lumina 7300 reflective with Avery 1360 gloss laminate.
Quick note, the posts were stained before we installed the sign and it's at the edge of a farm field in the middle of nowhere so I kind of doubt vandalism would be the issue.
The materials you used seem to be fit for the job. If you're printing solvent ink, how long did you let it off gas before laminating? If not long enough, it can cause issues like this.
DL Signs
Never go against the family
Did you lay it wet? It's the best way to lay some reflective, but if you trapped moisture in it and put it out in the sun, all kinds of mean, nasty, rotten, ugly things can happen with the reflective materials. Depending on what you used as an application fluid, like home brew soap & water based ones can cause mold too if they're made too concentrated and get trapped. I throw this out there because it looks like it's happening in a non printed area, but just like Solventinkjet says, you really gotta let solvent inks out-gas.
Good call, both material data sheets say no wet applying so could be that as well.
Mike Paul
Super Active Member
I agree never apply reflective wet.
That looks like U/V damage burn to the silver in the reflective material. Seen it happen before on the best material; especially on Black trucks that hold a lot of heat in the sun.
Anything reflecting on it like a bracket or something?
rydods
I'm not exactly sure how long the outgassing time was but typically we let prints sit overnight before laminating so 12 + hours.
rydods
We don't apply anything wet. I've had issues with reflective earlier on in my carrier with wet application and we use Guardian Roll laminators for applying the laminate. We have a Rollover application table and I'm quite sure we used it to apply this print as reflective is a pain to apply by hand.
rydods
One thought I had was that maybe had a piece of something under the print and we tried lifting it then heating it back down which left slight bruising which may have become more "pronounced" overtime??
rydods
I looked at the sign myself at midmorning and the sun wan not hitting the face of the sign so I likely gets sun later on in the day. I have several signs with this material/laminate combination all around. Some full ink coverage and others partial and I haven't seen anything like this.
