calculating press time cost
CKCUSTOMKC
Creating a quoting tool for myself to use, and I was curious how you all calculated press time? is there any benefit to doing it as an hourly rate vs a flat rate? any input would be greatly helpful as I know there are a lot of factors that go into it
Modern Ink Signs
Check the specs of your machine. Each print mode prints xx sq.ft. per hour. From there you should be able to figure out your time and costs .
rjssigns
hp latex 315, i guess i need to get better about putting detail in my questions lol
Got it. I posted in another thread about using a digital stopwatch to get exact times for everything from travel, to set up, printing etc...
Beats guessing or looking at the clock.
CKCUSTOMKC
I have everything figured out for time and what not, I just dont know how much to charge per hour of press time, or should I charge a flat rate for press time? but basically I need to factor in wear and tear on the press to cover maintence costs, I just dont know how much to build into the pricing
rjssigns
For my shop that's covered in the square foot pricing. Prepress and postpress is charged at shop rate per hour.
  • Agree
Reactions: 1 user
CKCUSTOMKC
What factors do you know of so far?
I have all my factors pretty well covered except the actual cost of the wear and tear on the machine, and the upkeep costs, basically I dont know if I need to charge 20 an hour of press operation costs? or like a flat rate of $100 to simply use the press? Im kinda just looking for a number that will cover maintenance and general wear and tear costs, I dont know if that should be a flat fee or an hourly charge
CKCUSTOMKC
prepress and post press is covered in a different cost analysis for us, this is just focused on the press itself, I know there are electricity costs and other upkeep costs, but I dont know quite how to delineate that into a perjob cost
rjssigns
I would calculate the fine details such as electricity, print heads etc.. Use that data to either do a per hour or average yearly cost divided by estimated jobs per year.
For my TIG welding I got granular and was shocked that it cost 21 bucks an hour when welding. That covers electricity, tungstens, fillers, cups etc...
Not sure if any of that helps but it's a long boring process that needs to have every facet measured multiple times.
You want repeatability within a narrow margin of error.
  • Agree
Reactions: 1 user
Notarealsignguy
Arial - it's almost helvetica
it's not a press. just saying
Are you familiar with the term depreciation? Figure that part out and cap expected costs. It is going to be different for everyone. Stop calling it a press too, not sure if I already said that
  • Agree
Reactions: 1 user
