Caldera Print Standard Verifier Tool
jasonx
Does anyone know if the Caldera Print Standard Verifier Tool using the ICC profile when print the test targets or does it disable the color management?
I want to confirm that each time you perform the task with this tool you're testing your current ICC profile with the current linerasation to see if it passes the standard or if its only testing to see whether the physical output device is capable of reaching the particular standard.
The documentation I either don't understand properly or it doesn't mention this.
