Can I get some input on this please?
Moze
I'm not a font expert (obviously), but I know spacing between letters isn't always exactly the same from letter to letter.
The attached photos show the bottom serifs of the 'R' and the 'E' closer together than the 'A' and the 'L'.
Is this an error or is that just how this font is supposed to be?
J Hill Designs
its more about the 'visual feel' than the exact measurement between serifs.
The RA is closer because the R opens up to the a
the AL is farther because the L stops the eye dead
seems the EA is a little loose is my input
Moze
I assume you meant the 'R' and 'E'...?
Anyway, I get what you're saying. And I agree, it looks like the 'E' and 'A' should be closer.
That looks more accurate to me.
SignosaurusRex
For this particular type face and these four characters in that order, I think that the space between characters at the base line should be nearly equal to one another.
Moze
Thank you for all of the responses.
My assumption was that when the wording was laid out in whatever program, you just typed out what you wanted and they were automatically spaced. Is that not how it works?
John Butto
When I typed it out it came out just like your pattern. So that is how it works.
Rick
When you say automatically, it will only space how pairs were programed to space
by whatever software you are using, or how the type designer spaced them...
You either have to manually kern them, or some programs like Illustrator for instance
has an option where you can "Optically" space them from your "Character" window.
You still might have to adjust here and there, but it gets pretty close.
ddubia
Auto kerning gets them close. But like everything else, if you enlarge something the mistakes get bigger too. Auto kerning works ok for the most part at a small size. But when enlarged, as in the letters for a sign, those small inconsistencies get bigger and easier to notice.
Just my 2 cents.
