Can someone convert for me?
Salmoneye
I have a CDR file but use illustrator and versaworks. The customer sent a PDF as well but some background textures disappear once I put it in versaworks. Can someone convert a CDR to an EPS so that I can open it in Illy or use it in VW?
Zophus
Take the pdf and drag and drop it into new illustrator document, then before you embed it go to object, flatten transparency, convert text to objects if needed and OK...
Hope this helps
Salmoneye
Thanks Zophus, I tried what you said and nothing. If I view the attachment and let google handle it I see the textured backgrounds in the art. If I follow your instructions it originally places the file in a bounding box without the textures but solid color backgrounds instead. When I flatten it using the alpha channel or spot color options nothing changes, still no textures.
Zophus
Sorry I thought it might work.
I use that when customers send me a pdf without the text outlined...
I don't have Corel Draw to help... Sorry
