Can the Canon Arizona 1360 flat bed print beyond 96"?
JdBattDesignRCI
If I have a 48x96.5" inch sheet of coroplast and the bed goes to 48x96, can it go beyond the 96" width and by how much? I know it can go past the zero inch mark on the left because bleeds are possible. Reason I ask is I have a 2-sided 48x96 sign to print and the sheet is actually 96.5 inches wide. if I flip over the sheet to do the other side can I offset it Y=.5" and not worry about the bleed? Or will the design get cut off at the 96" mark and mess up the double sided print?
SignMeUpGraphics
Super Active Member
Spec sheet says maximum width for rigid media is 98.4" so I would say so. Our 360GT (metric) goes to 2500mm which is also 98.4".
You may only have the 96" ruler printed onto the bed, but it should still print out to the full 98.4".
Easy way to test, put a piece of masking tape over the ruler and try print a 98" single point line across the width.
