cap station not holding fluid...
ABBOTARTDEPT
When i disway and nozzlewash (or try to) the black cap station wont hold the fluid. it will just empty out without the pump working. the other 3 caps work fine. anyone ever experience this?
Case
usually a key indicator that a new pump is needed.......pump is weak or not fuctioning often....
case
ColesCreations
Check the pump manually, when turning it forwards, it seals, turning it backwards opens it. If only the black- it's probably bad, as 2 heads / pump.
RippinPC
Most likely cause is pump failure. Not a total failure, but it no longer 'pinches' the tube closed when in the 'nozzle wash mode'.
New pump will fix this. If you replace one pump, you may want to go ahead and replace the other.
Chris
RippinPC
