CG-160 FX origin problem
Artist369
Ok so i have run into a small problem. I was die cutting some decals just fine, then all i changed was the pressure for the next set and my origin is off. Usually once i run the material and it gets the measurement the spot that the laser is sitting is where the blade will start, but all of the sudden it is about 3/8" back from where the laser was. Not sure what changed or how to fix it. Any help would be greatly appreciated.
Commando
There is a page in the manual that shows how to do a measurement test. Might be out of square. Just look at the manual or call Atlanta
