I had been using a lynx cutter with flexi v8.5, without issues, I now aquired a Mimaki cg90 from a defunked business, i've configured it using the driver provided in flexi, but every 1st job I send I get an INV AGR offscale error on the cg90, then I delete the job in flexi, clear data on the mimaki without turning it off, then I can resend the job and it works fine, up until I turn the unit off.. any suggestions? the previous owner says he had never encountered this issue before..
I dont have a manual for the mimaki so i'm running a bit blind, I cant verify any of the serial port settings in the plotter as I have no idea how to get to them. The unit did not work at all with my serial cable from my lynx, now im using a usb-rs232 adapter and having the above problem.
I have plenty of computer experience but im not sure what to check without having any sort of documentation / settings for the mimaki.
THanks
THanks
