Last week our CG60-ST started to skip when cutting. It usually cuts horizontal/vertical ok, but on the diagonals it skips. I have replaced the blade, and adjusted the height in both the positive and negative directions. I have tried different speeds/pressures/offsets. It does it on heat press vinyl and on regular oracal 651. Another thing it is doing is not cutting square corners. Any suggestions??
