Cleaning cartridges
midnightmadman
Does anyone have a rough idea how much fluid needs to be left in a cleaning cartridge to run a cleaning on a 1204. I have 1 full and 3 about half and don't want to run it if that's not enough for the 3
henryp
If you are thinking of flushing the ink system by performing a Head Wash (now called a Longstore on newer models) procedure through the printer's control panel, you will need a full set of new cleaning cartridges,
midnightmadman
Yes
I’m installing a new head & maintenance station and wanted to flush the system because it’s been sitting with no head for a couple months
My other question is am I risking anything if I do this with the new head installed ? Or am I better off just pulling or something different ???
henryp
Yes
I would not want old stale ink to pass through the new print head
Henry. Since you say there is no head it will be sufficient. I would hook up my syringe with a y connection to bottom of both same color dampers. You can connect directly to the ink lines without dampers. It all depends on what connectors you have. I would the put the cartridge in the slot. you can pull as much cleaning fluid through as you want. make sure you pull the cartridge out as you are finished puling to empty the line out.
