Colex Flatbed cutter problems
Almengel65
I have a Colex Flatbed cutter. It isnt acting right. I have a cut file for the part that I am cutting, but when I go to cut it cuts lines that arent even on the cut file and cuts almost wherever it wants. Has anyone experianced this before or have any ideas? I am very new to this machine.
Thank you
Christian @ 2CT Media
What program are you using to design the files?
Have you gone in to wore frame mode to see if there are any hidden lines? Are you converting to a specific file type for the colex software?
MGB_LE
We typically use Illustrator to prepare our cut files. I'm certain that some test files came with your Colex. What are the results when you use those? Have you been trained in the use of the machine?
MGB_LE
a77
Probably not your problem, but you never know. We create our files in Illustrator and one thing we have found is that if a PDF has extra CutContour paths in hidden layers, Caldera will use them to cut. You do seem them in preview, but noone looks at that because we just scan the barcode and let the cutting go.
Not sure if that might apply to your workflow, hidden cut lines.
Fernando Chavez
FernandoATX
Thank you
Hello,
I'm looking in to buy a Colex. Could you share with me your experience working with them? Did they fixed your problem with your cutter?
If you had a chance to buy a different cutter would you buy Colex again or would you look into another brand?
Thank you!
MGB_LE
I'm still in love with our purchase, 2 years later. We've cut paper to foam to acrylic to metal and even wood. I only wish for a more robust user community to bounce ideas off of. The table itself is pretty darned accurate and tough and reliable.
Fernando Chavez
FernandoATX
Thank you
Hello, I'm thinking in buying a Colex. Would you recommend it?
