I use Flexi 10 and Photoshop CS5. I export from Flexi to eps, open in Photoshop and apply layered effects, save as a PS file, import into Flexi, add contour cuts and send to VersaWorks to print from my VersaCamm. My problem is my colors get messed up, particularly yellow which gets a green tint I can't get out. I have tried using CMYK in Flexi and opening as CMYK in PS, as well as RGB in both applications. The best results I got were with CMYK in Flexi opening as RGB in PS, but it still has a green tint. I know that might seem weird as I have understood you need to keep your color the same mode. Saving with or without a profile in PS seems to make no difference. I realize I am using 3 applications, but I don't like printing from Flexi because it uses so much ink. What is the best way to cross applications and get predictable color? Where do I start?
