Colorip profiles help please!
boggiom72
Anyone still using colorip?
I downloaded profiles from Roland and from Wasatch for my FJ740...
The ones from Roland are good for everything but they all have a yellow ochre shade.. So my blue is basically a muddy green...
The ones from wasatch if run on medium resolution have perfect colors but banding, wether if I set at 14000 dpi they saturate too much and I end up having way too much in on my media...
Any idea? Also bidirectional or unidirectional setting affect the profiles?
Thanks!
m
kirkbauguess
You can change the saturate levels. Go to print, then set up, then edit,then color transform. On the lower right hand side you will see a box that says ink limit. In that box will have the saturation level. Raise that number up, more ink. Lower that number, less ink.
Unidirectional will have less banding.
