Colorprint pu printer set up
BSL Graphix
I've only ever used EnduraTex Darkjet Solvent and just used a basic print profile with all heater setting set to 30 degrees. I'm going to give the ColorPrint PU a try this weekend, and was looking for some advice as to setting up my printer for it. Should I print with same setting as I have been doing with DarkJet? I read where I should heat press the ColorPrint at 330 degrees, which is a little cooler than DarkJet (375 degrees). Thanks for any input!
