Colorspan UVR Prime Bars
Signs2u
Just moved and reinstalled our UVR and now the Prime Bars won't print at all. The print recovers jet pattern does print. Anyone know what the #$()) might be going on?!
Thanks in advance!
-Mike
SublimeGraphics
did you make sure it is perfectly level. While i have no idea if this is the cause, the tech that installed ours made it very clear these machines need to be perfectly level to run properly
Signs2u
Colorspan 72UVR Problem
Pictures of what is going on... Please please please help.
Mspec
you should not be seeing that much ink on your drip tray, I would wager that you have an overfilled head or another vacuum problem. Is there ink in your vacuum tubes above the heads?
