Hi to all of you!
Sorry for my english but I will try to be as clear as I can..
I own the very new VS 540i and I use Marabu DI LS inks in sealed 440ml cartridges.
I have setup the printer from the beggining without white and metallic but only with 2XCMYK.
My problem is that after every day in the morning when I start the printer the nozzles of 2 channels of Magenta are completely missing.
After a medium cleaning all nozzles of Magenta channels are coming back
in excellent contition. The machine prints well and unstopable until the night without problem but the next day the magenta channels are completely missing again..
The other colors are in excelent contidion.
I made a full choke cleaning because I thought the problem comes from air bubbles on the magenta ink lines but with no success. The next morning again the same story.
I also have change the cap top without success.
The only I can suspect is that the magenta ink lines divided into two tubes inside the machine and there are also two pumps for circulation when you setup the machine for white and metallic. But these pumps does not work at all because I setup the machine as 2XCMYK from the begining.
Any help would be appreciated.
