Concrete wall cover up sign question
ozpall
Hello,
I have a client that wants me to cover up the name the have on the wall right now,
so just looking for recommendations on what would be some of the options i can give them. i was thinking something like screwing max metal but since it so long not sure how its going to look with multiple panels.
any input much appreciate it.
thank you.
unclebun
Since it's smooth concrete where the name is you could probably get the MaxMetal panels to line up and butt together correctly, unlike what would happen on the brick. It would be even smoother to screw either treated lumber stringers or square aluminum tube to the wall and then screw the sign panels to the tubing. Then you can actually make the sign larger than the concrete area so you just see brick behind it. That way you also don't have to put the masonry screws through the MaxMetal. In fact, if you want to get tricky you can use a no visible fastener mounting. Or you could attach the sign panels to a frame that holds them all together and use standoffs to mount.
MikePro
not a fan of fasteners through the face, but if they don't mind it then let'r'rip!
I'd be doing studded aluminum panels with textured paint to match or contrast existing, with new aluminum or PVC lettering mounting atop
JBurton
Signtologist
I'd sell a banner today, then a 2" framed aluminum panel, hung with 90s, mount some cast gemini or flat cut painted letters to it.
  • Agree
Reactions: 1 user
